Cet
Capitol Copy
I'm having some white ink alignment issues with my CET 250H. I'm using the CET Print Controller Version 3.1. When I print using white ink with the "middle layer of image" option my white ink is perfectly aligned. However, if I use the "middle layer" option my white ink is out of alignment and I get a white sliver(1mm) on one side of the image.
My heads vertical calibration and left/right calibrations are dead on. I've tried several different files and I always get the same result.
Has anyone else run into this?
bluehammer
Off topic, But how do you like your 250h? I'm looking at buying one.
