CG 130-FX stops during cutting
teddybier
Hello everyone,
Ive got a Mimaki CG 130-FX, and sometimes when i plot, the machine stops after a couple of centimeters, usually about 20-30 cm. The machine asks then "sheet or roll" and measures it, same behaviour as when you load a new roll, or boot the machine. usually this happends only once, and the next time i start the plot it works fine. But today it wont work. Ive changed the speed and pressure already, but that doesnt make a difference at all.
I rang up the vendor, and they will call me back, but i dont know when.
Do you guys know what the problem could be?
Problem solved.
The problem was the rear sheet sensor, i used videoflex, which is a bit shiny, and the sensor had problems detecting it. Switching it off solved my problems.
