CG-130FX Cutting off
AnimalG82
My cutter has been acting up over the last couple of months and its to the point where its a daily occurrence. It will cut perfectly fine on a couple of jobs, then it will leave some white at the top on a job and correct itself not too long after. So I go into the settings and adjust for it, and then it works fine. Well now, after I adjust, its fine, then the next job after is off again. I've done the 400mm square and I've tightened the belt as well and I don't think it can be adjusted anymore. So my question is, how difficult is it to replace the belt? I've had the cutter for quite a few years and everything is original except for blades of course. Also, will this actually solve my issue? Thanks in advance.
signguyms
Member
They are not to bad to change. Does the cutting strip have a groove in it. The one I change the belt on didn't help but the cutting strip did
