CG-130SRIII pressure issues
datablitz
I have a 3 month old mimaki cutter and all of a sudden it takes almost twice the amount of pressure to cut my material properly. What used to take 30-35 pressure setting now needs 50-60. I have installed two different new blades, and the problem has not changed. Everything else on the machine looks normal. Has anyone seen this issue before?
Sent from my SM-G955U using Tapatalk
Make sure the black ring around the blade holder is under the tightening mechanism. It's a common first time user mistake. If the ring isn't under, the blade holder just starts to slip a little each time and will require more pressure.
datablitz
Yes, I did make sure the ring was under the locking tab. I am beginning to suspect it is not going to be a common issue
L.D
Have you tried replacing the Blade holder? I had a customer with the same issue, we replaced the blade holder and it fixed the problem. When we took the old one out and shook it a bit the blade popped out.
Worth a try if it’s covered under warranty.
datablitz
I have not tried that. The blade sits well in the holder, and I can not shake it out, but it's worth a try. Thank you
