We would like to run our CG160 FXII where we can capture the plotted jobs on a roll without cutting each job off the machine individually. The problem is, when you lift the rollers to make an adjustment, then hit ROLL, it scrolls to the front edge, or about 15', whichever comes first. We then have to scroll it back to find the marks and that up-and-back movement can cause enough creep in the material that it can't detect the marks. Is there a work around for this? Maybe hitting LEAF instead of ROLL? Maybe there is an adjustment in the machine or software that turns off the machine's attempt to find the front edge every time? Solving this would be a big time saver. Thanks in advance for your help!
