Changing Ink Configuration:: VS540i
Discussion in 'Roland' started by splizaat, Aug 12, 2020.
  1. splizaat
    splizaat Very Active Member
    1,238
    4
    38
    Sep 19, 2007
    Pac NW
    Hey all -- we bought a new printer and need to swap a setting over that we are having trouble with.
    Printer #1: Showing ink type as "E-SOL MAX2 LkW"
    Printer #2: Showing "E-SOL MAX2 7C"
    Both printers: Exact same cartridge configuration: 7Color + Cleaning Cartridge.
    For the sake of simply loading and running the exact same profiles for both machines in versaworks, the ink type needs to read the exact same. BUT, when going into service menu > Change InkType on the new "MAX2 7C" one, there is no option for LKw. In fact that's only a few options in there, none of which are Eco-Sol Max2 except the 7C option.
    Does anyone know how to enable the setting for "E-SOL MAX2 LkW"? The ink cartridges themselves are not changing, just simply need to change this one setting and all of our profiles will work since both are running 7colors + cleaning cartridge.
  2. SignMeUpGraphics
    SignMeUpGraphics Moderator
    1,357
    286
    83
    Apr 11, 2012
    Australia
    Are they both the same model printer running the same firmware version?
  3. splizaat
    1,238
    4
    38
    Sep 19, 2007
    Pac NW
    Yes! I was able to use a VS-640 ink type changing instruction just now, followed by Ink Fill and it is now working properly and profiles auto-populated with our other printer's profiles as soon as we added it back to VW.
