Changing opacity of a pic in X3
Discussion in 'Corel' started by PGSigns, Mar 17, 2007.
  1. PGSigns
    PGSigns Active Member
    560
    I am working on a banner design and doing it in X3. I have a pic I want to use as the background and want to change the opacity. I looked everywhere and can not find how to do it using X3. I ended up doing it in photoshop to get through the design but there has to be a way to get it done in X3. Any help would be great.
    Jimmy
  2. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
    Convert to bitmap.....
    then go into Image Adjustment Lab.
  3. Rodan68
    Rodan68 Member
    94
    Mar 6, 2007
    Bay Area
    If you want the background lighter you can add a transparency lens on top of the image. If you want the background to show through something behind it use the interactive tranparency tool on the tool bar. From there you can apply gradient transparencies as well as uniform transparencies to your image. You can also use this tool to lighten the background as long as there is white behind the image.
  4. bob
    bob Major Contributor
    5,273
    306
    83
    Nov 4, 2005
    earth
    That won't allow you to change its transparency.
    Do this...
    Select the object to be make transparent.
    On the Effects tool bar flyout select the Interactive Transparency tool. It's the wineglass looking thing.
    Put the cursor on one side of the object and drag to the other side. This should leave you with a gradient transparency.
    Change it to a uniform transparency by selecting 'Uniform' in the first drop down in the properties bar.
    Select the percent transparent by either moving the slider or entering a value in the text box in the properties bar.
    There you are. You also can apply a transparent lens to a vector object as well, but his method works with either a bitmap or a vector object.
  5. VISUALCONCEPTS
    VISUALCONCEPTS New Member
    19
    Thanks that a great tip
  6. PGSigns
    560
    Thanks I knew it was there just could not find it and was not having any luck with the manual. Been getting better at Corel since I got this printer and learning something new everyday, just not enough days in the week.
    Jimmy
    :thankyou:
