cheap tablesaw
John Butto
So your a newbe[video=youtube;RBucMKhrL8M]http://www.youtube.com/watch?v=RBucMKhrL8M#t=465[/video] and need a table saw...
Pat Whatley
All that bracket building and hinging wasn't needed. First one I ever used the guy had just screwed through the deck of an old saw and into a piece of plywood. Flipped it over, stuck it between two sawhorses, BAM....instant table saw. All the adjustments on the saw still worked.
JgS
I use to work construction and we would do that all the time when we were too lazy to haul around a table saw.
TammieH
+ 2 for screwing a circular saw to a sheet of plywood
I'd rather by a table saw than go through all that work
But, I guess if you like tinkering around in the shop/garage, have at it!
GAC05
Quit buggin' me
I have to wonder if this guy's full time job might not be building ACA websites for the Feds.....
wayne k
guam usa
visual800
It never loaded for me and I dont wait forever but you can buy a ryobi table saw for $100. Obviously this guy is a genius and has to be doin something
bob
Dangerous assuming that the blade's turning the wrong way trying to grab the work out of your hands and walk its way on top of it instead of pushing it down onto the table and back at you like a real table saw. Exactly the same problem when attempting to rip on a radial arm saw. Dangerous.
artbot
OldPaint
BOB...........you need to watch it again.
he has the blade rotation correct for a table saw. he cut a board and the small piece kicked back at the operator. CORRECT!!
as for ripping with a radial arm saw........YES DANGEROUS.......IF YOU try to rip with the blade from the wrong direction. a radial arm saw can RIP, but onlyif you feed it from the LEFT..INTO THE BLADE ROTATION. i have a radial arm, and have ripped many 2x4, 2x6, 1x4's all day long...........as long as you feed material from left )))))
