Hello, I am trying to do a circle both print and cut. When I print using my mutoh 1624 the edge seems really good and clean but when i go to cut them using the kona 1400 the edges are no longer smooth and the cutter "stutter steps" while cutting it. So it takes a lot longer for it to cut and its not as clean as it should be, or rather as i hope it would be. Anyone have this issue and if so how do I fix it? I use flexi 12.
Thank you
Thank you
