sfr table hockey
Just wondering if any other CJ 500 owners that have converted to solvent, have changed their drain line tubes to a larger diameter tube?
The very thin drain line works well with waterbased but the solvent seemed to dry and plug quite easily.
I picked up some black brake hose tube and set it in the solvent cleaning solution for a few days to test to see if it softened. So far no deterioration so I am going to try some and also mount the drain bottle in front so its easier to see and get at.
So far much better on the cleaning cycles before the caps were taking longer to drain and as the heads moved off them you could see the pooling in the caps. Now with the larger drain line its back to normal where once the heads move off the caps the caps are drained already and not pooling for a second or two.
Just a thought.
Just a thought.
