ONYX-BERLIN
I own a CJ-500 converted it to an SC-500 and he has been nothing but great so far. Now i experience a a really awkward situation.
During the print cyan started to fade out and banding appeared. Looking up the issue here on Signs 101 I came up that ink starvation most likely would be the problem and started a cleaning run and air leak check on everything from the cartridges to lines, dampers, capping, heads etc. Did the cleanings cleaning, sucked on the capping station mith a syringe got nice vacuum and ink flow.
Test print absolutely horrific..
maybe 3-7lines on the left printhead on each color k,cy,mg - then changed the lines with the dampers of printhead 1 to printhead number 2 and vice versa - same horrible test print just diffrent colors.
Then changed the heads 1 to 2 and 2 to 1 still same pattern. But the head that created the horrible pattern produced now in slot number 2 a perfect pattern. So heads are both ok.
Swapped printhead ribbon cables, swapped the long ribbon cables from the mainboard - nothing changed
Another weird thing that happened today when i started up the printer it said "temperature too low" even though there was around 25 Degrees Celsius so perfect temperature - also it said "temperature too high"
One thing i might see as a problem it was very humid and hot so maybe static created a problem on parts of the printer or the mainboard.
Did anybody have the same issue? Is it the main board that's screwed? Does anybody know what options I have on the mainboard to check fuses and transistors. Could somebody please help as i invested days to fix it and need help by somebody who maybe knows the electrical side.
Thank you so much
Thank you so much
