Need Help [CJV-300][Video] PR Sensor problem
cryptod
Hi,
So today i had a serious media jam in my CJV300 white it was cutting vinyl. It was so bad the vinyl got stuck in the pinch roller sensor and was able to move it from its place and unplug it. The printer started showing me "PR SENSOR" error every time i try to use the cut head.
After finding out the problem and plugging back the sensor (thanks to the maintenance manual), it was able to switch to cut mode and use the cut head. But now when i try to go back to the main head this happens (see video) and the printer then shows "CUT HEAD HOME POS." error.
Any idea ?
Neil
On my CJV30 there's a switch in the cutter head and a little 90 degree folded bit of aluminum on the carriage that fits into the cutter head to activate the switch.
Yours may be bent or not inserting or activating properly.
Albert Ma
Hi,
Any idea ?
Hi Mate, I have same problem with you, how did you fix it in the end? thank you
I've got an cjv150 same issue banner jammed up now same pr and 522 error code any for sure fix I'm in the middle of a job can't afford any lost work during covid-19 any help would be great thank
Error 522 is a media width sensor error. I'd bet the head strike knocked it out of place. Make sure it's sitting in it's spot properly and clean the surface with alcohol. PR errors are similar. There is a sensor in the back of the index head that reads the position of the pinch rollers. If it got knocked out of wack, it won't read the proper position or at all.
kirsmith
Hi,
Any idea ?
Hey!
So this happened to me yesterday and I scoured the internet looking for a solution and came across this problem. I just wanted to upload a photo of the piece that had come loose and how it sits in there so that if this happens to anyone else at least there is something somewhere. I got the "c head home pos error" message and when my metal guide piece went to attach to the cutter unit it was snapping and wouldn't attach.
I took the black plastic cover piece off that the metal guide piece clips to, and there was a hole going horizontally where I placed the black heavy pin-rod thing, the "Y" piece is oriented up and the "L" shaped piece is oriented down. This allows it to turn/swing as it needs to to clip into the metal guide piece.
