CJV30 problems doing big wallpaper pictures
bmw_ante
The problem i get is that the color differs a lot when i then put the image together
One wallpaper breadth gets lighter than others etc
Look at the picture
The picture is tiled in Rasterlink and then printed one after another
Any ideas?
I agree with signage, try flipping every other panel. In case you didn't know, on the tiling layout screen just check "reverse even numbered columns".
I'm not sure if it has to do more with the printer or the material but every printer that I've ever worked with tended to print slightly lighter on one side . It's never been obvious enough to see until you place a tiled image together.
~Chris
bmw_ante
I have now tried flipping every oyher panel, It is less obvios now but i think it is to big difference.
What more could help ? Higer or lower resolution, More passes, Overprint, Drop size ?
Letterbox Mike
Try a different profile, flip every other panel, run the printer slower at a higher resolution. I've also had success adding a little bit of noise to the file in Photoshop to help blend things together, it's helped with that for me in the past. But the biggest thing is printing with a good profile, that will eliminate alot of that.
bmw_ante
[/URL][/IMG]
