CJV30 Won't Cut.
Rojo
When I send a file through Rasterlink or Finecut it won't cut.
In Rasterlink I'm getting this:
Data Output Error < {268445185} > - [Command Output Error] - (0x08018023)
It prints fine. It's getting some cut info. The head switches to the cutter but it stops at that point. I restarted the computer, turned off and unplugged the printer. No change.
Anyone had this issue? The manual offers no answer.
JoCkeWe
Solution
Try setting the line-width in cut-layer to 0,1mm instead of 0 in Illustrator and dont print the lines. This fixed it for me.:peace!:
If that doesn't work for you, try a new USB cable and port. If you get the same issue, try re-installing the latest version of the Mimaki USB driver.
