Cleaning HP Latex Printer Rails with 95% Ethanol
GB2
Old Member
Just wondering what all you HP Latex owners are using to clean your carriage rails. HP recommends 95% Ethanol but is that denatured or not? What are you using and where are you getting it?
Dan360
I just use Isopropyl Alcohol, when techs come to work on our printer they ask to use it as well if they didn't bring any.
GB2
Old Member
Actually Isopropyl and Ethyl alcohol are two completely different formulations. Ethyl alcohol is what liquor is made with in a pure state. Denatured alcohol has additives to make it unfit for consumption. None the less it is irrelevant because HP recommends 95% Ethanol (which I believe is synonymous with Ethyl Alcohol), unfortunately they don't specify if it should or could be denatured and they don't provide any further information.
signbrad
There are many alcohols. They are hydrocarbon molecules. Three commonly used alcohols are also among the simplest molecularly.
Methanol, methyl alcohol, is the simplest. It is highly toxic and has little use in the sign industry, though it is inexpensive. It is commonly used as an antifreeze and as a fuel. It is also used as a "denaturant" for ethanol.
Ethanol is ethyl alcohol. It is the alcohol in whiskey and other beverages. It can be sold as a general purpose solvent by making it poisonous. This is done by adding a small percentage of a toxic substance, such as methanol, and it is then sold as "denatured alcohol."
Isopropanol, or isopropyl alcohol, is often mixed with water and sold as "rubbing alcohol." A mix of 70 parts alcohol to 30 parts purified water is common for use as an antiseptic.
All three of these alcohols are miscible in water. Methanol is miscible in both oil and water.
A Laphroaig Manhattan is made from Laphroaig scotch, sweet Vermouth and a dash of bitters. This Manhattan variation has a smokey flavor due to the peatiness of Laphroaig scotch, which comes from Islay. It is a delicious way to enjoy ethanol.
If you are ever in Lawrence, Kansas, visit John Brown's Underground and order this cocktail from Dante or Logan and tell them Brad sent you.
ikarasu
I didn't know methanol was that bad .We use it a lot... I pretty much have a huge bottle upstairs that I use to clean Coro before I print on the flatbed .it eats UV ink good too when I need to fix a mistake.
I always spray some and wipemit off without a glove. Worst it's ever done is cause my skin to be a bit dry.
Googling says people have gone blind from constant skin exposure / spillage, and even breathing it in is bad.
Guess I'll be requisitioning some isopropyl :mad:
Bly
Our tech said we should use acetone instead of iso to clean the rails.
We still use iso.
signbrad
I have been corrected. Alcohol is not a hydrocarbon, but a derivative of a hydrocarbon. Hydrocarbons contain only hydrogen and carbon. Alcohols have in addition a "hydroxyl group," which is a hydrogen atom bonded to an oxygen atom. So...hydrogen, carbon and oxygen in lots of varying combinations make lots of different alcohols.
I'm glad that was cleared up.
Here's a link to a textbook page about alcohols. It's from the BC Open textbook project.
I like the little diagrams chemists make to show how molecules are put together.
20.2 Alcohols and Ethers | Chemistry
GB2
Old Member
Well, here is my answer to my own question. It's available at any local liquor store for a reasonable price.
akuarela
which type of cloth material would be best to replace the sponge for the carriage interconnect wiper
Rubenmutt, I think that material is almost or the same as the synthetic chamois used for cleaning cars.
For the other cleanings, I use a polyester lint free cloth used for cleaning uv printers @Amazon :
Cleanroom Cloth Wipes 9"x9" (Bag of 150 Pcs) Double Knit 100% Polyester Wipers Lint Free Cloths with Ultra-fine Filaments, Laser Sealed Edge, Class 100 Cloths, Ultra-soft Wipes CP14009​
