Clear vinyl, Reverse Sticker
daenterpri
A customer of mine wants to know if I can make a reverse sticker on clear vinyl to stick on the inside of a window.
I'm still new to this Gerber Edge, can I do that? What material would I need to get?
Andy
J Hill Designs
you need clear vinyl...most likely with a white overprint
sooo set up the file, send to GSplot, mirror, and in the 123 dialogue reverse print order...
should do what you want...
iSign
3M/Gerber 220 clear edge-ready vinyl... set up your job, then in composer, or in GsPlot, flip (axix-swap) your design & add a white backing set as overprint, (or using the "backing vinyl" tools which I find confusing & don't use)
If it is a 4-color process print, I usually reverse print order as well.
its very, very easy to do. as they said above reverse print order, use the 123 dialoge box(that will be your friend!!). double check in gspplot to make sure all is well and then print. we also do it on static cling with good results.
daenterpri
Thanks everyone! I'm excited to try this. Where's the best place to buy static cling material for the Edge 2?
