CMYK colortest seems off ? (CJV30)
justroll
I printed a CMYK test (100% of each color) on S21 CMYK inkts
my output looks like this, the yellow band the dithers are the best visible,
file was a AI file in CMYK document setup
also checked with color replacement in rasterlink and indicated 100% for each color but visible it isn't 100% yellow only
fyi the dither isn't black (so no overspray from the lines that border the band)
any ideas ?
hand851
Roland Mutoh & Mimaki inks digiprint-parts.com
can I see a test print of the nozzles?
Looks like heat issue.
justroll
any ideas ?
turn colour managing/icc off in your RIP if you want pure CMYK.
as far as i understood, this isn't possible in rasterlink if the device profile doesn't support it.
I'm using the default mimaki device profiles for PVC for this, in color matching the only options are defualt & mimaki enhanced
Pauly
Printrade.com.au
That's odd, i havent used that RIP before but im sure there should be away not to use ICC profiles or turn it off. unless you can make custom spot colours
justroll
as requested ..
heat issue? i used the media profile of siser soft print, i got the media as well here, tested, but same problem
