CoCut not advancing the vinyl
tintgirl2000
This is going to be a simple fix for most of you.
I use corel draw and cocut pro 2011
My summa d60 has always advanced the vinyl after the cut.
I replaced the power supply and since then when it cuts it doesn't advance after the cut.
PLEASE HELP ME
Its pretty annoying not to be able to send another job right after the cut otherwise it would cut on top of the first one.
thanks
This would typically be a firmware setting on the cutter itself (return to origin / set new origin), and/ or a setting in the application that is driving the cutter (CoCut in this case). I have no experience with CoCut, and only limited experience with Summa brand cutters, so I cannot be more specific.
