After using a Colex Sharpcut for years if you have literally any questions about it, ask away. I'll go over some details.
Colex 5x10 static or conveyor- 220v single phase 50 amps. Steel welded frame, solid design, rack and pinion driven by Panasonic servo motors. Independent vacuum zones with 6 pumps that are able to be switched on or off depending on the size of the sheet you are working with (most people leave all on).
Software side uses 2 programs. Colex CNC and Optiscout (which Zund used to use and what Summa uses)
The machine is fully 3d capable and the cnc software is open source so you can use pretty much whatever 3d modeling software you want.
If a part were to break the machine is designed easy enough that a tech could remotely walk you through how to replace the part.
The support is A+
Multicam started as a router company who later came to introduce knife cutting capabilities. They are considerably slower in the knife dept. Nobody can question their routing capabilities or the frame as they are both solid.
Most finishing companies are a la cart (zund,esko,summa) Colex is 1 price and you get whatever you need including all software, workstation with computer, vacuum for table suction and debris extraction and whatever tooling you require. Zund likes to reel people in with attractive numbers in the 100k range but when you start adding vacuums,computer, routing module, dust extraction it can easily climb to over 220k. Also their frame is a skeleton that will need a tech to come out and re-level If you run into any issues.
Summa seems to do the same at less cost. I will tell you this. If you plan to do ANY sort of heavy routing DO NOT go with Summa. Their router module (kress) is so overpriced (8k) and underpowered it's not even funny.
Do yourself a favor and stop at the Colex booth at SGIA and speak to A TECH that's running one of the machines. You will get all the info you need and not a sales pitch.
