Colex SXC1732 vs Esko X24
bigben
Not a newbie
I'm doing my homework to buy our first flatbed cutting machine. Right now we are between the Colex SXC1732 and the Esko X24. We will mostly use it to cut rolled material like vinyl but will start to do dimensional sign in-house instead of sub it out. For the cutting we will mostly do 1/2 thick acrylic and 3mm dibond. That been said, on paper they seems to be pretty similar but I would like to have feedback of real world users.
Thanks.
LarryB
I have had a Kongsberg X24 since December and love it. Use it for everything to cut rolls of banners and decals along with router cutting. Make sure to get the heavy duty spindle if you do a lot of router cutting.
bigben
Not a newbie
And what make you choose this machine over any other brand/model?
LarryB
I upgraded from a Multicam 3000 router and needed something with faster soft cutting and roll capability. I looked at the Kongsberg X24 and a Zund and picked the Kongsberg as it was significantly cheaper and felt the quality is just as good. My personal opinion is the X24 is a step above Colex. Just my opinion as I've seen people who love the Colex's.
There are some good YouTube videos on the X24. One is from Grimco which is about an hour long and it goes into detail cutting all the different materials. I would talk to your rep for both cutters and go see them at a customer's location. Also PrintUnited is coming up in Las Vegas
JstevensonPrints
Printing dreams one day at a time
There are many other options, check out the folks at Cutworx in Texas, they have thousands of machines in the field and the machine is great.
bigben
Not a newbie
I'm located in Canada. I want to deal with a company that will have a local technical service with a good reputation in case of a problem.
Zse444
Zsolt
Hi! Check the maximum speed and spindle power! We have one X44, in the technical spec was the maximum speed 50m/min. and 3 kW spindle power. The fact is, that the machine achieve the 50 m/min only diagonal (4 directions) when the X and Y motor goes together with their ~30-30 m/min speed. And the spindle S1 power is only 2 kW. They are lying! Please check yours! Zsolt
V. V.
Inkjet printing guru
As a former FSE and person extremely familiar with cutting tables world I have to tell you something - Kongsberg is as simple as the best option ever.
Both mechanically and software wise - robust, reliable, versatile and easy to operate. Neither Zund nor Summa can get to the same level of being user- and service- friendly at the same time, not mentioning any chinese and another manufactures.
Zse444
Zsolt
Hello, I posted my first thread with my experience. If you interested, you have Kongsberg/Esko machine or you want to buy read, and ask If you have a questions:
Kongsberg/Esko cutter bad experience, speed and power problems, technical issues​
cesargraphics
How is your Kongsberg X24 working out looking to get one? Thanks
cesargraphics
Thanks.
Hello what machine did you end up going with? Thanks
We have a Colex 1732...best thing we ever bought for our shop. We looked at Zund, but Colex was much cheaper and felt the quality was as good. We've had it for 5 plus years now with no major issues. Plus, it's made in the USA!
The best thing though, is their tech support is out of this world! I highly recommend Colex.
bigben
Not a newbie
I'm waiting to have the place and $$$ to get the 5x10 table. But we will definitely go with the colex. The kongsberg looked good but it's a 3 phases machine and we don't have it here. We could buy a transformer but it would cost more than the colex in the end. Plus colex technician is local to us compared to kongsberg.
cesargraphics
Thank you for you Reply! I ended up pulling the trigger on a Kongsberg X24 Edge. I do have 3 Phase in my building. Looking forward to sharing more of my experience on here.
greysquirrel
Rotary converter from American rotary is 5-6k
Glavin_ID
We have been running a colex for many years. Great machine but ours is getting to the end of its life so time to start looking for a new one. We love colex, but probably since that is all I know. Can someone enlighten me on what makes a Kongsberg so much more expensive, especially when their advertised speeds are significantly slower than Colex (specifically on the X24)? I hear everyone say that Zund and Kongsberg are the top level machines, but I am having a hard time justifying the higher cost without a tangible advantage. I have read all the threads on here but a lot of folks seem biased to the machine they know/have experience with. Anyone out there have experience with both willing to share what makes one better than the others?
LarryB
I have had my Kongsberg X24 for almost 3 years and love it. Only down a handful of times. Their support is good as they have talked us through issues. I have preventative maintenance done every year and that helps too.
