Color distortion at start of print
Discussion in 'Digital Printing' started by Roberts Printing, Jun 2, 2011.
  1. Roberts Printing
    Roberts Printing New Member
    1
    I have a Mutoh Falcon Outdoor 46. At the start of the first image in a run I am getting a dark band that starts black then fades to the actual color and clears up after 1/2 inch and doesn't appear on any of the following prints. Any thoughts. I have cleaned the heads, wipers, etc. with no affect.
  2. P Wagner
    P Wagner Very Active Member
    1,913
    80
    48
    Aug 16, 2006
    San Diego
    Sounds like you are describing cross-contamination. This can be attributed to several possible causes, including inconsistent amounts of ink in colors going to the head, maintenance station issues (wicking), and in severe cases, damper problems.
  3. Gino
    Gino Premium Subscriber
    33,287
    2,321
    113
    Jun 7, 2006
    PA
    Welcome from PA............................
  4. Rooster
    Rooster Very Active Member
    1,208
    1
    36
    Feb 22, 2008
    Edmonton
    Definitely a case of head contamination at the capping station. The head is wicking up waste ink back up the lines through the head and until you force some new ink through the lines, it's printing with the cross contaminated ink.
    A likely solution is to lower the height of the capping station so the actual head isn't making contact with the foam or fluid in the capping station.
  5. heyskull
    heyskull Very Active Member
    1,662
    15
    38
    Sep 2, 2007
    UK
    I would suggest installing a new capping station and clean all the pump pipes.
    SC
