Color Management Issue for Mutoch VJ 1324
EZ Ink
My printer is printing magneta for red and the yellow is very poor. Black and Blue Colors are fine. Cleaned and nozzeled check a few times. Also set the software in color mangement too RGB 1998, it was orginally on sRGB IFC61966-21. Open for suggestions on what to try next. It was working the day before just fine. Thanks.
EZ Ink Promotions
jcskikus
Owner, Designer & Installer
How long have you had this printer? Leave those settings as they are as it sounds like you have a printhead issue. Always check the physical prior to changing software settings. Also, have you ever taken any courses on using Flexi software?
EZ Ink
I shutdown the printer. An hour later went back and turn on. I next printed four yellow squares, maybe to clear the line. Cannot explain it, but it worked. Printed my client banner, no problems
That's a sign that your dampers need to be changed and/or there's an air leak somewhere in the line. Might be time for a maintenance.
