Hello all,
I'm new at vehicle wraps. Done a class before through Orafol, but literally about to go insane wrapping this RV. I've wasted so much material and money that I'm just searching for any tips I can get now.
I've got a 38ft RV that I'm wrapping (It's mine so I'm getting some expensive practice). I'm having a big problem with applying large panels. These panels are about 9ft in length (40-50" in width) and everytime I get half way down, the panel starts flaring (stretching) out to the sides. Basically the middle lays down and the edges have about an inch of slack - Causing a nightmare to apply the rest. What am I doing wrong? It must be the way I'm squeegeeing the panel down. The material I am using is Orafol 3551RA with the 290 laminate.
Here are my steps if it helps:
1. Line up the panel
2. Tape the sides of the panel about a ft down. (I've tried 2 ft)
3. Fold the top back and tear off the backing
4. Apply the top ft.
5. Start working down the panel moving from the middle to the right, then middle to the left at a 45 degree angle while I start peeling off the backing.
6. Half way down.. Nightmare
I appreciate anyones help on this..
