compound cutting paths
thirty6
Hi All
When i try to cut a graphic which has three seperate cut paths in it (motorcycle panel) the cutter (gerber hs15) cut a path then drags the blade over to the next path without lifting the blade fully, so damaging the laminate.
If i cut multiple images with one cut path each it does not drag between them.
It is a setting i am missing or should the three paths be seperate or compound??
Any help really appreciated.
Cheers
Matthew
thirty6
rjssigns
In Illustrator I use Pathfinder to Merge individual paths. Then I click Compound Path>Make. This leaves you with a single "contour" for cutting.
Hope this helps.
