Connecting Graphtec Cutter to Mac Cutting Master2
Trying to get my Mac (OS10.7) connected to Cutting Master 2. Not having any luck.
Here is what I have so far.
1. Downloaded latest Cutting Master 2 software from Graphtec Website. It does say it should work with 10.7 Lion
2. Connecting via usb cable.
3. Set up the cutter as a Graphtec FC7000-130.
4. In the properties window in the port pull down menu it lists USB. Under device it shows Composite Device. It appears that it can see the cutter properly because if I unplug the USB cord it shows device undetected.
5. When I go to plot/cut and press the poll media size button it just keeps spinning and never tells me what size of media is loaded.
6. When I try to plot a simple rectangle I get a message on the cutter, Error 1 Instruction Not Recognized.
Any Ideas?
InkjetAuction
GP-GL vs. HP-GL
The FC7000 series does not have auto sensing for the command language, so you will need to set it to GP-GL (vs. HP-GL) for use with Cutting Master.
Go into the Initial Settings menu (before you load media)... you should see a Command option. Here you can choose GP-GL. You can also get to the Command Language options through the regular menu system.
I'm guessing that this is your problem...
~E
Sticky Signs
That's what worked for me. Poll size still doesn't work. I have to input the page size manually but at least it's cutting.
