Contour Cut an EPS
Discussion in 'Flexi' started by stevelv, Nov 13, 2006.
  1. stevelv
    stevelv Member
    44
    This is probably a very easy question but I can't seem to work it out.
    If I import a vector EPS file into Flexi, how on earth do I get it to contour cut around the outside? If I select it and CC it then it just draws a contour cut line as a large rectangle around the whole thing.
    I'm tearing what little hair I have left
  2. MobileImpact
    MobileImpact Active Member
    759
    once you import it, ungroup it and delete the bounding box. then select it all and go to contour.
    This should do the trick
    Kevin
  3. stevelv
    stevelv Member
    44
    Got it!
    The darn eps was masked and that's why I couldn't get rid of the bounding box - after I unmasked it everything worked fine. Thanks for the help
  4. MobileImpact
    759
    no worries, glad to help
