Grafix USA
Ok, normally I run jobs of <500 but I'm running a job of 3000 5"x2" decals and have broken them down into 3 jobs of 1000 each. I am using the FC7000MK2-130 and want to know if anyone has a better way of setting up.
I use the "sheet" command at the begining and then set the origin. As you can imagine if I'm off just a little it gives me the mark scan error because it has to go through so much material. Should I be using the "front roll" or "rear roll" setup at the beginning of the job or is "sheet" the correct way to do it (and I just need to get better at aligning my vinyl and setting the origin)?
After 3 tries I got it to work and align correctly, but with such a large amount of vinyl any misalignment seems to waste alot of time.
Any suggestions or ideas?
