Contour Cut Lines -Appearing on print - Flexi to Versaworks
Tim Kingston
I had seen this problem posted before but couldn't find it in a quick search. Cutting a .PSD file in Flexi ( no stoke , transparent background ) using contour cut command, exporting as an .EPS , importing into Versaworks , print and lcut. The contour cut line is printing out ( very faint ). I can go back and bring the cut line in some but was wondering how to fix this. This is the first I've had the problem, thanks for any help.
Tim Kingston
Bobby,
Thanks for the offer. I went into Illustrator and had a real close look and saw that there was a slight pixelated line in the original bitmap that I didn't see in Flexi. I just brought in the cut line in a little bit and all should be good. Sorry for the trouble and thanks again for the offer of help, much appreciated. Tim.
