Contour Cut Problem
Discussion in 'Flexi' started by Lad2010, Apr 25, 2005.
  1. Lad2010
    Lad2010 New Member
    10
    I am trying to contour cut a rectangle with text inside. When I turn on the contour cut effect, it puts cut lines around the rectangle and the text. Does anyone know how to turn the cut line for the text off?
    Thanks for any help!
  2. jayhawksigns
    jayhawksigns Very Active Member
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    Can you just select the rectangle and apply the contour to it?
  3. Dennis Raap
    Dennis Raap Active Member
    586
    Oct 5, 2003
    USA
    When making a contour cut look at Design Central there you can set the Offset, then check the box With holes if you want the text cut out if not uncheck the box only the rectangle will be cut.
  4. Lad2010
    Lad2010 New Member
    10
    Thanks for all your help.
  5. trauts
    trauts Member
    119
    contour cut
    if i'm using a oval or rectangular backgroung i select the background only and then select contour cut and set to -.005 and it cuts just a hairline into the edge of my backgroung to eliminate white margin unless you want to have some white on the edge.
