Contour Cut Query
Discussion in 'Flexi' started by jthomason, May 18, 2009.
  1. jthomason
    jthomason New Member
    5
    Hey guys, this ever happen to you?
    So, I've imported a file into Flexi 8.0v3 that I designed in Illustrator CS3. They are decals for a softball team. Everything is vector. I go to contour cut to make a nice, .125" contour around these decals and it acts likes it's doing it but nothing happens. I can't see the contour cut line. But if I go and actually right click on the image it will give me the option to either clear or separate the contour cut.
    So I'm thinking to myself, okay, maybe I need to split these decals up. So I uncompound them. Well, now it works just fine (I should have thought of that first anyway). So I'm going through and hitting cut contour on these decals individually and I get half way through and then it just acts like it did before. It won't show the cut contour outline. The ones that it worked on before I get to this one are still visible. Just the others now won't work.
    First of all, did I explain this well enough? And if so, what gives? Anyone have any idea? I can figure this out and get the job done. That's not my problem. I just hate when something happens and I don't know what the heck is going on.
    Thanks guys!
    Jasin
  2. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    I'm not one of the many Flexi haters around here, because it does what I need it to do... but my personal choice of "what I need it to do" almost never overlaps with anything I could just do in illustrator. If you design in illustrator, why don't you just create the vector path you want to use for your cuts in illustrator as well?
    I agree that what you are explaining sounds like something you should be able to expect consistent & acceptable results from in Flexi... and now that you are there, trying to do it... it seems like going back to Illy is an "extra" step... but in the future, I would do everything in Illy that Illy can do, and only leave what Illy can't do for Flexi to do.
  3. thewood
    thewood Very Active Member
    1,781
    Dec 28, 2005
    Tennessee
    I would recommend taking one of these graphics and creating a .125" transparent outline around it. Group the outline and the graphic together. Go to Effects>Contour Cut and add a contour cut of zero to this grouped graphic and outline. Step and repeat the resulting contour cut graphic as needed and print/cut.
  4. bob
    bob Major Contributor
    5,285
    308
    83
    Nov 4, 2005
    earth
    Why not just make the outline you created the contour cut via Arrange->Contour->Make Contour Cut? The you won't have a superfluous path hanging around.
  5. thewood
    1,781
    Dec 28, 2005
    Tennessee
    Because it sounds like that method is causing issues for the OP. Sometimes Flexi will hang up when applying a contour cut to a complex image. Outlining the objects and then applying a contour cut is a workaround for that issue. Perhaps I misunderstood the original query.
  6. bob
    5,285
    308
    83
    Nov 4, 2005
    earth
    Try to follow along...
    If you can make an outline as per your original recommendation then it's simpler to change that outline to a contour cut than it is to make a contour cut around that outline yielding Yet Another object.
  7. thewood
    1,781
    Dec 28, 2005
    Tennessee
    Gotcha. That makes perfect sense.
    And, jthomason, how are you coming along?
