Contour Cutline printing out- Flexi ~Versaworks
Tim Kingston
Hi,
I know this topic has been discussed before but after a quick search I couldn't find it. My problem is using Flexi 10 and Versaworks is that the Contour Cutline is printing out in Versaworks ( 5.0), every once in awhile I run into this and usually bring the cut-line in a bit to get rid of it. However I would like to know how to fix this properly, I can't remember what the solution is. In most cases, I think it happens on a transparent bitmap with a contour cut applied in Flexi. Thanks for any help.
ImpactSignCo
The only thing I can think of is to check and make sure your contour cut line swatch is the proper spot color called "CutContour." You can create any spot color in Flexi, as long as you use that name, to use as your contour cut line. As long as it's a spot color with that name, Versaworks shouldn't recognize it as printable.
The only time I have run into something similar is when trying to print white on our XR-640, where the swatch wasn't set up properly.
oksigns
Hi,
Can't mix raster effects such as transparencies or drop shadows with spot colors. If you do, spot colors are interpreted as CMYK, thus the reason your cut lines would show.
Flatten your artwork as a rasterized image like a tiff, and then paste in place your live cut lines on top, and then send it in to versaworks
