contour cutting with cg-75 fx
Discussion in 'Mimaki' started by tattoo.dan, Jun 27, 2010.
  1. tattoo.dan
    tattoo.dan Active Member
    564
    8
    18
    Aug 3, 2009
    Southern Il
    can anyone help me with this? i am not having any luck getting the cutter to read the marks...i am printing and cutting with flexi sign pro 8/1. thanks dan
  2. SightLine
    SightLine Premium Subscriber
    I had made this up for someone else some time back and should help you some too.... one thing though - my default material width is wider than yours should be as I am using the CG-130FX which is just a wider version of the cutter you have.
    http://www.sl-digital.com/CGFX/
    The above folder is browseable - read the readme file first. I made screenshots showing my exact cutter config in Production Manager and on the job settings screen. I also listed the options on the cutter itself and took a photo of where exactly I set the cutter to the registration mark. Hope this helps...
    Richard
  3. MikePro
    MikePro Major Contributor
    4,966
    233
    63
    Feb 3, 2010
    Racine, WI
    change your cutter marks... easiest fix.
    There's a type1 and a type2 (one's like a box, and the other's inverted like a .psd artboard, just figure out which type flexi outputted as when you set your cutcontour and change the settings in your cutter to match....
    I believe its function>setup>markdetect, but I've only found it by digging around the function menu on the cutter when i changed mine.
