controltac on a steel building
Discussion in 'Materials' started by Drip Dry, Dec 1, 2010.
  1. Drip Dry
    Drip Dry Very Active Member
    1,122
    1
    38
    Aug 11, 2004
    Long island NY
    We're doing a job for another shop and they requested controltac IJ180
    to be put on a steel painted building. It's like the back door of most commercial buildings.
    I'm not so sure how good it will adhere since the glue doesn't seem to be so aggressive in the first place. So, I put a small sample on my own back steel door and it stays on, but you can just lift it off.
    I realize it's made for wrap material. We plan to heat it once it's on, but I'm not sure if that's going to do much.
    Is there some type of edge sealer or glue I can use to make sure the edges don't lift ?
    Should I insist on using something different ?
    Any comments ?
  2. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    Painted steel is a common substrate in this trade.
  3. HulkSmash
    HulkSmash Major Contributor
    8,159
    140
    63
    Sep 10, 2010
    Denver.
    control tac is fine. i do it all the time.
  4. signswi
    signswi Very Active Member
    2,136
    2
    Make sure you're applying enough pressure during install to activate adhesion.
  5. thesignexpert
    thesignexpert Active Member
    841
    2
    WARNING! - In normal circumstances during the summer you would be fine with 180c. You should consider one important factor though... you are in New York with freezing cold temperatures right? 180c is supposed to be installed with the surface temperature at least 50 degrees. In addition, even after the install you need that surface to remain at 50 degrees for several hours to allow the adhesive time to bond properly. An exterior wall like this is a big potential film failure just waiting to happen if you don't tent it, warm it up, install, and then keep it warm for a while.
    Good Luck!
    Tim Evans
    The Sign Expert .com
    Free Forms for Sign Professionals
    Pro Sign and Graphics
    "A Pro Sign Made Easy"
  6. Turtle
    Turtle Member
    50
    Tim makes a good point. I wouldn't install in temps lower than 50 degrees.
    With that being said there are adhesive promoters out there to brush around the edges. 3M makes one called primer 94 or p-94. Another good one is pro-bond.
    Good luck
    Mark
  7. HulkSmash
    8,159
    140
    63
    Sep 10, 2010
    Denver.
    just installed control tac on a 48 foot trailer in 18 degrees.
    worked fine.
  8. klemgraphics
    klemgraphics Active Member
    624
    Jan 13, 2008
    Midwest
    Bet that was fun!
  9. ProWraps
    ProWraps Very Active Member
    3,556
    Sep 30, 2009
    San Francisco, CA
    buy a spring scale and do a pull test. nothing we say matters your conditions and needs are unique to your project. do your homework and decide for yourself.
  10. HulkSmash
    8,159
    140
    63
    Sep 10, 2010
    Denver.
    no :( ill post pics later.. it started snowing too..
    we leased our space where we are now because we could fit a semi in it. who knew there was something bigger?
  11. Drip Dry
    1,122
    1
    38
    Aug 11, 2004
    Long island NY
    Concerned look on his face.... just when I thought the paranoia about this job was starting to fade, thesignexpert has to bring the cold weather up.
    Job was promised and has to go up Tomorrow. Expected 38 degrees.
    Walks away knowing he won't sleep tonight.
  12. andy
    andy Active Member
    848
    1
    Didn't think you were supposed to install any vinyl when it's less that +5c ?
  13. Malkin
    Malkin Very Active Member
    2,193
    26
    48
    Feb 11, 2009
    Augusta, ME
    You'll be fine. 38F is no serious cause for concern.
    Carefully use a little extra pressure and perhaps post heat it with a heat gun.
    Controltac adhesive activates with pressure and/or heat.
    Ultimately though, Prowraps is 100% right.
  14. Drip Dry
    1,122
    1
    38
    Aug 11, 2004
    Long island NY
    Done !
    34 degrees + a 23mph steady wind blowing straight in.
    Actually went pretty well except for the cold
    8 more locations to do. Maybe we'll wait to January when it's warmer
