copyright symbol
PGSigns
I have a folder with it and a few more things I add to files. Saved in a few differant formats so when i need it I just go and get what I need. Make your self a folder to keep this stuff in, then you will always have it.
Jimmy
MobileImpact
try holding the alt key, then type 0169. there was a post about this a while back with all the symbols etc.
alt 0169 ©
alt 0174 ®
alt 0162 ¢
alt 0149 •
Kevin
bob
I get tired of making the copyright symbol and never remember who I did it for, Isn't there a font that contains it?
Virtually every font file has the © and ® and a host of other special characters. You can access them directly if you know the code for the character. You merely hold the alt key and type either the full decimal code, including leading zeros or type x and the full hex code including leading zeros. In the above the decimal code for © is 0169 and ® is 0174.
Packages like Flexi and Corel and others also feature a special character insertion facility where they display the entire character set and allow you to choose what you want.
OldPaint
OR.....you can access it once with all the keywork, SAVE IT AS .cdr/.ai/.eps. or what ever program you work in...file....THEN YOU CAN JUST IMPORT IT AS NEEDED....
