Corel 2024 and Enroute 6
JTW
Just upgraded from Corel 2019 to 2024. 2019 to Enroute 6 works fine, but when we try to open a dxf from 2024 we get an error in ER. Is anyone else having this issue?
GaSouthpaw
I've never had good luck with anything but EPS from Corel to EnRoute, though the others Atilla mentions will work in a pinch- with CMX being almost as bad as DXF, as far as extra nodes and rough lines.
Cadman
Personally, I almost exclusively export PDF files with a sheet size that fits all the artwork otherwise there may be clipping. If it is something simple I just need a quick transfer of, I export CMX (Legacy works better for me) and never had an issue with either one, but PDF keeps the layers and I do all my separations and nesting in Corel.
Attila Nagy
Only recently started to use CMX. compared to EPS, CMX does not enclose object to clipping mask. I have not noticed any extra nodes or quality issues. It is possible to have different experience with different Version of CorelDraw.
GaSouthpaw
Absolutely- and I haven't used CMX since 2005 or so for that reason (and I'm running Corel's last release) . But I also don't send anything to EnRoute except what I need, so I can't comment on the clipping mask issue.
