Corel Question
Discussion in 'Corel' started by k.a.s., Dec 11, 2007.
  1. k.a.s.
    k.a.s. Very Active Member
    1,411
    4
    38
    Aug 8, 2003
    NE ohio
    I am using another shop to screen print some coro signs for me. They have not been using Corel very long and so we are running into a problem. I export eps. files out of Flexi but when he opens them in Corel they are not opening as a vector file. I saw him take the file from the e-mail and when it was imported it looked like a jpg. Is the more than on way to bring in the file? Anyone have any suggestions on why this would happen? Thanks in advance...
    Kevin
  2. Air Art Girl
    Air Art Girl Very Active Member
    1,907
    4
    are you sure you exported as eps? Cause I do export from flexi to corel all the time
  3. Jillbeans
    Jillbeans Major Contributor
    14,457
    19
    38
    Dec 24, 2003
    Butler, PA
    What # of Corel are they using?
    You might have to try exporting to a lower number (like when I send an .ai to my GA, I have to save it as version 7 or lower)
    They may also try importing it using the "PS PRN EPS Postscript Interpreted" command.
    That's the only way I can open Brands of the World files in Corel.
    Love.....Jill
  4. Bogie
    Bogie Very Active Member
    1,972
  5. vid
    vid Very Active Member
    1,442
    3
    38
    Jun 11, 2003
    California
    Is he openning or importing the EPS file?
    Typically OPEN rather than import works for us. They're getting the JPG preview that is created when you export from Flexi.
  6. Columbia Signs
    Columbia Signs Member
    300
    When you export the file to an EPS, make sure the "Sort Type" is vector and not Bitmap.
  7. gabagoo
    gabagoo Major Contributor
    5,740
    108
    63
    Oct 10, 2006
    Vaughan, Ontario
    in older versions of corel there are two eps import selections he should use the one that says encapsulated post script, always works for me. The other eps option usually just brings in a grey box with the letters eps in them like a bitmap
