Corel to Photoshop Layers
Discussion in 'Corel' started by JFP Studios, Jul 19, 2011.
  1. JFP Studios
    JFP Studios New Member
    20
    Using corel Draw X5, when I build a design in corel can I save it and reopen in Photoshop as Layers? What file would I want to save it as if this is possible?
    Thank you so much guys.
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    doubt it
  3. Roto
    Roto Member
    211
    1
    18
    Jul 19, 2011
    Australia
    Yep the filter Dialogue says you can!
  4. Morph1
    Morph1 Levelup Digital
    307
    11
    18
    Oct 8, 2008
    Edmonton
    export as PSD in layers.
  5. Jim Doggett
    Jim Doggett Very Active Member
    1,304
    1
    The PSD export is way cool, but in older CorelDRAW versions I'd always export an eps with the layers separated (side by side) which I'd break into separate layers in Photoshop.
    I even still do it that way, out of habit. And I always add a bounding box since the top of ellipses tends to get cut off slightly when exporting EPS files from CorelDRAW.
    So I'll have to try the PSD export and see if it does better, and save some time. Old habits die hard :^)
  6. Morph1
    307
    11
    18
    Oct 8, 2008
    Edmonton
    I just double checked it,
    it works like a charm !!! :wink:
  7. Jim Doggett
    1,304
    1
    Very cool!!! What a time-saver! May need to upgrade, albeit my CorelDRAW 9 (on Win 7 Enterprise 32-bit) just does everything I need, and I can do it drunk, stoned, blind-folded and while sleeping :^)
    So it made me a procrastinater on upgrading ... LOL
    But ya convinced me!!!
    Thanks for the great insight.
    :goodpost:
  8. Bobby H
    Bobby H Very Active Member
    2,150
    173
    63
    Feb 4, 2005
    Lawton, OK
    I wish CorelDRAW could paste AICB style vector paths on the clip board so they could be pasted into Photoshop, either as paths or shape layers. It's another reason why I have to run both CorelDRAW and Adobe Illustrator on my computer.
  9. Artildawn
    Artildawn Member
    311
    Jim,
    Just tested and it does work, but you'll have to plan in advance and set up the layers in Corel when you created the vector.
