coreldraw CDR to Flexisign
Discussion in 'Flexi' started by Valentino, Mar 1, 2007.
  1. Valentino
    Valentino Active Member
    675
    Jan 16, 2007
    what's the best way to transfer a corel draw image into flexisign
  2. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    export cdr as eps then import to flexi . . .
    or export cdr as eps then convert to pdf then import to flexi
  3. k6media
    k6media Active Member
    733
    make sure your versioning is ok with your eps or ai.. you'll find that flexi sign v7.5 and back has issues with versioning on files from Illustrator 10+.
    I find depending on the complexity of the artwork.. I go right back to saving as Illustrator 8.0, and it seems to work fine.
    k6 Media
    www.k6media.ca
    Advertising | Design | Signage | Vehicle Wraps
  4. Valentino
    675
    Jan 16, 2007
    I have flexi 8.1 by the way.
    ok I will try those solutions
  5. learned the hard way
    learned the hard way Active Member
    544
    This question gets asked fairly often. I have VE LXI Expert, which is a house-brand version of Flexi. I do my designing in Corel and then simply copy and paste into LXI for cutting. Some people say that copy/paste does not work for them, but it works fine for me. If it doesn't work for you, then Replicator's advice is good....export from corel as .eps and then import the .eps file into Flexi.
