For the past couple or so years I've been using CorelDRAW X5 and X6 between home and work. I recently installed a trial version of CorelDRAW X7 on my notebook at home, just after doing a factory reset to clear out some garbage that occurred from a recent series of "not ready for prime time" Windows patches.
Anyway, I'm finding more things I don't like about CorelDRAW X7 than things that rank in the positive. Version X6 will ask you to update text when reading in an older version CDR file. Version X7 won't leave you alone about the update text nonsense until you do it. This evening I found another even more annoying thing. Version X7 apparently has no clue how to correctly save down to an earlier version of CorelDRAW and keep fountain fills properly generated. If I save down to version X5 or X3 the file reads back in with the fountain fill changed dramatically. The differences are most apparent on radial fills. This is just as bad as opening Corel-generated fills in Adobe Illustrator or vice versa. I can understand the differences with Illustrator, but when it's happening between the current version of Corel and a recent version (even X6) it's very unacceptable.
Is there any settings I might be missing in CorelDRAW X7 to make it behave properly when saving files down to earlier versions, be it X6, X5 or X3?
