Corner cutter recommendation
Discussion in 'Product and Supplier Referrals' started by MHester, May 20, 2020.
  1. MHester
    MHester Member
    146
    6
    18
    Sep 13, 2016
    Timberlake, NC
    I don't do very many radius corners, but when I have the need I sure wish I had one rather than outsourcing. I'm looking for a small table top corner manual corner punch that I can use on .040 aluminum and 3MM ACM board that cuts 1/2" radius. Don't want to spend more than $200 on it, if that's even possible. Any recommendations? Thanks.
  2. Ardor Creative
    Ardor Creative New Member
    20
    5
    3
    Dec 17, 2019
    Worcester, MA
    The Lassco-Wizer CR50B is what you need. It's more than $200, but for 040 and ACM it works perfectly. Purchased mine from MyBinding.com, and pretty sure they had the lowest price. I probably have used mine at most a dozen times but it's gonna last me decades so the $300 was worth it
    • Like Like x 2
    • Agree Agree x 1
  3. 2B
    2B Very Active Member
    2,999
    371
    83
    May 5, 2011
    TX
    Not within your budget, but we have been very happy with ours
    got an Arbor Press from Harbor Freight, have done up to 080 alum
    • Like Like x 1
    • Agree Agree x 1
  4. Notarealsignguy
    Notarealsignguy Active Member
    690
    161
    43
    Feb 20, 2020
    Florida
    • Like Like x 1
    • Informative Informative x 1
  5. bannertime
    bannertime Very Active Member
    2,161
    503
    113
    Sep 8, 2016
    No
    Are you using the xpert tool dies on that?
  6. 2B
    2,999
    371
    83
    May 5, 2011
    TX
    https://www.cutterpros.com/xpert-sign-tools-xpert-corner-rounder
    we paid 368.99
    Did not get the base, while the unit can move on the Arbor press. it does not interfere or slow down the rounding process.
    In fact, for the odd sizes, it is helpful to be able to rotate the rounding tool
    bannertimebannertime the dies are built into the unit, 1/4 1/2 3/4 1
    you rotate the base to the radius you want.
  7. bannertime
    2,161
    503
    113
    Sep 8, 2016
    No
    Do you ever feel like 1in is enough? Most of our premade sign blanks are 1 1/2in. I feel like it would be odd for us to move to 1in.
  8. 2B
    2,999
    371
    83
    May 5, 2011
    TX
    Yes, We have reached out to the manufacture about doing a 1.5", 2", 2.5", 3" configuration.
    we Have not heard back from them though, grated it was over a year ago. Maybe with the downtime, they would entertain the option more.
  9. Notarealsignguy
    690
    161
    43
    Feb 20, 2020
    Florida
  10. MHester
    MHester Member
    146
    6
    18
    Sep 13, 2016
    Timberlake, NC
  11. bannertime
    2,161
    503
    113
    Sep 8, 2016
    No
    It would be a no brainier for us. We bought the arbor press as soon as we found out about their tools, but it was a hard stop after we found out what sizes were available. I don't want to spent $1000 of metal when it doesn't do what I need it to do. The hole punch is still enticing though.
  12. Notarealsignguy
    690
    161
    43
    Feb 20, 2020
    Florida
    We have 2 of them and they work good. It takes some fiddling with it to get the die aligned when you set it up but not a big deal.
    Also have a Lassco CR-50P and a mittler bros press with the 4 sided die. The Lassco doesnt do well with aluminum so we still use the cheap ones on 040 and 063, its faster than the press.
    • Agree Agree x 1
  13. rjssigns
    rjssigns Major Contributor
    5,157
    517
    113
    Jun 4, 2007
    Home Office
    Couple decades ago I bought a fairly expensive die. Made a wood table(from scrap) with recess to hold the die. Last bit was the metal handle(also from scrap). It was a fun money saving project. Haven't tried cutting 0.040" aluminum though.
    • Like Like x 1
  14. GB2
    GB2 Very Active Member
    1,911
    80
    48
    Nov 15, 2005
    Connecticut, USA
    I have an Accucutter Cornermate 080, which is a little costly but does a great job...and has a 1 1/2" die
    http://www.accucutter.com/
  15. MHester
    MHester Member
    146
    6
    18
    Sep 13, 2016
    Timberlake, NC
    Thanks everyone for all your advice and recommendations :) This is the best place ever to get personal feedback, thank you Signs101 :) Y'all have a good day, and stay safe out there!
  16. BobM
    BobM Very Active Member
    2,138
    43
    48
    May 31, 2008
    Cape Cod
    I've had my accucutter for 12 years. Never had a problem with it. I was surprised how many customers comment on nice rounder corners. Well worth the money.
    http://www.accucutter.com/[/QUOTE]
