Coroplast/Foamboard Cutter
mike59413
Hi, im building A table and I want to build a coroplast cutter, so that I can mount the cutter to my table, does anyone have any suggestions as far as which cutter to base my design off of? and I was also wondering if anyone knew of a method of applying vinyl to both sides of a sheet of coroplast at the same time? how would i go about doing that.
thanks again!
RycckG
Look at the tables made by Esko/Kongsberg or Gerber . Both use tangentally controlled reciprocating or ultrasonic knives. Not what thickness you are needing to cut. They both have vacuum tables also, which I would highly recomend...
