bigben
Not a newbie
We print several rolls of phototex per month. We just did an install and I have one panel that have one 1/2in crease on the edge of a seam and like a 1/4in bubble on the bottom part of the panel. It wasn't there when I've applied the panel. I can sqeegee it down flat, but it still cumming up. I've never encounter that kind of problem with this material. With a regular vinyl, I would just heat it up a little and voilà. I don't want to reprint and reinstall the whole panel just for that.
So since this will be a permanent install, I was thinking to use maybe glue to hold everything there. I have opening for the 1/2 crease I could inject the glue and for the 1/4 bubble, make a small cut and inject the glue.
So my question is: Does using glue is a good solution? If yes, what brand/type should I use? If not, what are my other options?
Thanks. Ben.
Thanks. Ben.
