Hello All,
My shop is taking on a sign build that we have not encountered before and I was hoping that I could get some expert advice on the fabrication.
The general outline of the project is a roughly 8'w x 4'h custom corten or weathering steel sign. We work with a local company that will cut the face for us, but then we need to determine the best way to mount the thing to the front of the building with a box for the LED's. I was thinking of having them use a 11ga (.125") sheet to have enough thickness to avoid any waves, but this adds some extra weight to the structure.
I have floated the idea of a SignComp aluminum box, but we have gotten kerf cut tops before and they are a bear to bend and never end up being the correct shape. We usually have to add an additional piece to form the proper shape. Our shop has taken on a lot of new avenues over the last 29 years, but metal fabrication is not one of them. We have made boxes out of pressure-treated lumber and ACM, but no sheet metal bending.
Any thoughts? Here is a very early mock up of the sign. It is meant to have a solid sheet of Lexan behind the face to make all of the elements glow white at night. Almost forgot, the other concern is discoloration of the Lexan. This is a steel that is meant to have surface rust and I imagine that rust will run as it gets wet. Not sure of the best may to prevent this or if just simply spacing the Lexan away from the steel and adding weep holes would do the trick.
Thank you in advance for any constructive advice.
