Covering (wall mounted) sign boxes w/ banners?
Discussion in 'Installation Equipment & Techniques' started by White Haus, Apr 21, 2020.
  1. White Haus
    White Haus Formally known as RJPW..........
    573
    160
    43
    Apr 6, 2018
    Winnipeg
    Working on a project for a customer that is re-branding a couple of locations. They want to cover up their existing sign boxes with a temporary banner, which will be up for 3-6 months.
    Both locations are in different provinces so I can't do a proper site check.
    One box is 74" H x 96" W (lexan face) Wall mounted on corrugated steel building
    One box is 80" H x 236" (Flex face) Wall mounted on corrugated steel building
    Is it feasible to do this with a banner? Can you just add a 3-4" bleed on each size so that they can wrap around the returns and screw into the box? (Is that even safe/smart to do?) They don't seem too concerned about drilling into the boxes.
    Given the size of the larger one, and how expensive shipping will be, I might try to get a local company to do a proper site survey and handle the whole thing depending on how this goes.
    Trying to look after this customer but also want to make sure this is done properly, which is hard to do remotely.
    Thanks guys.
  2. WYLDGFI
    WYLDGFI Merchant Member
    1,197
    108
    63
    Oct 27, 2006
    Linden, NJ
    Sure. Banner works...have done many times for clients.
  3. The Yanki & The Brit
    The Yanki & The Brit The Yanki & The Brit Signs and Radio Show
    231
    62
    28
    Sep 3, 2014
    Texas
    I don't do much banner work anymore, but I have seen that done in many places around the Metroplex....
    But for the sake of MY sanity, will you make sure it is on straight? ;)
  4. CanuckSigns
    CanuckSigns Very Active Member
    3,391
    391
    83
    Nov 11, 2008
    Ontario
    Hey Pat:
    We have done this in the past for clients and it's never been an issue, we did it for 2 politicians for the last election where they couldn't justify $3000 + on a sign face for a temporary campaign office, they were up for 3-4 months and were in great shape when they came down. I got the banners printed at 4over and had them put grommets every 2 feet, then just used self-tapping tek screws to screw the banner to the box.
  5. Billct2
    Billct2 Major Contributor
    7,463
    642
    113
    Mar 12, 2005
    New England
    Just give yourself a good margin and extra material for the wrap. That way exact measurements aren't critical
  6. unclebun
    unclebun Very Active Member
    Although screwing into the cabinet would work, I would take issue with putting a ton of holes in a light cabinet. More entry points for water, and multiple light leaks. And if the screws are too long and placed just wrong, wiring damage. Unless they are going to discard the cabinets when the new signs come.
    If the coverup is truly temporary, duct tape would work...comes in colors to match the cabinet.
  7. White Haus
    573
    160
    43
    Apr 6, 2018
    Winnipeg
    Thanks for the tips fellas!
    Unclebun, I'm a little concerned about this too. I think just to be safe I would encourage them to cut the power to the box for now while temporary banners are in place, and have the company installing new faces down the road patch/fill the holes when that time comes.
  8. White Haus
    573
    160
    43
    Apr 6, 2018
    Winnipeg
    Thanks Scott. Where you happy with the 4over banners? These banners will have a fairly solid grey (yay) background so I'm a little concerned about quality. I need to outsource them either way but hadn't considered 4over. One is in AB and one in SK so either way shipping will be involved.
  9. CanuckSigns
    3,391
    391
    83
    Nov 11, 2008
    Ontario
    4over is my go-to for large banners, the quality is perfectly acceptable for this application. You can order a small sample banner to your shop of the design for less than $20 if you want to make sure before you pull the trigger. Only issue I've had is on occasion the grommets are too close to the edge of the banner and I feel they could rip easily, so I usually order the banners hemmed and put the grommets in myself.
    Signs365 just rolled out Canadian shipping, I've never used them but they have good reviews on here.
    • Like Like x 1
  10. White Haus
    573
    160
    43
    Apr 6, 2018
    Winnipeg
    Sweet, thanks. I'll check out S365 as well, but 4over's pricing on these banners is pretty damn impressive. Not much more than my cost to print them in-house.
  11. WYLDGFI
    1,197
    108
    63
    Oct 27, 2006
    Linden, NJ
    We can ship to Canada as well FYI. Our greys are solid and streak free. ;)
    • Agree Agree x 1
  12. JBurton
    JBurton Signtologist
    1,836
    363
    83
    Sep 28, 2017
    Arkansas
    Last time I did a temporary banner, I went through a lot of extra work to make sure it would cover the face and then some so we could screw into the cabinet. I woke up the night before in a cold sweat, thinking about all the sh*t you might run a self tapper into, all the holes you will put in a lit cabinet, and how hard it would be to make sure it is going to be level when finished. I trimmed the banner to the face size and screwed it straight to the lexan. Poor guy hadn't even been in the office for a month before the gov shut down dentists...
    But really, go straight into the face with screws. Plastic holds pretty well with self tapping screws, and you will not be introducing areas where wind can get behind the face, like you would if you folded and tucked the corners. Not to mention the immense time savings, especially considering the customer doesn't give enough of a sh*t to pay for an actual face change...
    • Like Like x 2
  13. Texas_Signmaker
    Texas_Signmaker Very Active Signmaker
    4,519
    1,659
    113
    Oct 21, 2016
    Frisco, TX
    THIS^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
    I had a client buy a bunch of locations around the country and we had everyone install the banners to the sign face directly. Self tapping screws w/ washers... no worry about how it looked when it was wrapped around the cabinet, no damage to the cabinet, and from the pictures of the installs you'd be hard pressed to discover it was a banner... if it's a pan face just put the banner on the flat part of the pan. (Just remember to turn the cabinet off to prevent a bleed at night) And make sure that local codes will allow it.
    It's always best to get a survey from the people that you'll use to install it. These are simple, get a survey, order banner and drop ship from S365 (or whoever) and get the installers to install.
  14. White Haus
    573
    160
    43
    Apr 6, 2018
    Winnipeg
    Thanks guys, I like this idea. Do you have any pictures of how it turned out? I'm just wondering how visible the washers would be.
    I take it hemmed edges & grommets may not be necessary if we go this route? Customer is hoping to "re-use" them afterwards but we all know how that goes.
  15. WYLDGFI
    1,197
    108
    63
    Oct 27, 2006
    Linden, NJ
    If its hemmed and grommeted....fender washers, it can probably be used again if screwed into the existing plastic face. Shouldn't be an issue. Re-use...is a relative term as well. Sure its going to get hit by elements and all.
    • Like Like x 1
  16. JBurton
    1,836
    363
    83
    Sep 28, 2017
    Arkansas
    I totally forgot how hilarious this dentist's last name is... This was a 5'x10', 20' or 30' up, grommets every 12" and no hem. Originally it was just going to be a couple of months, otherwise I would have folded and grommeted at the least.
    • Like Like x 1
  17. White Haus
    573
    160
    43
    Apr 6, 2018
    Winnipeg
    Thanks! And yeah that is a pretty ironic last name for a dentist lol.
  18. Gino
    Gino Premium Subscriber
    33,326
    2,328
    113
    Jun 7, 2006
    PA
    Ya might wanna make sure if it's acrylic or poly before you go drilling holes and self tapping screws into it.
    • Like Like x 1
    • Agree Agree x 1
  19. JBurton
    1,836
    363
    83
    Sep 28, 2017
    Arkansas
    This is true, but also has me wondering; on an existing face, how would you go about figuring it out? I know most embossed and pan faces are poly. In fact, I'm hard pressed to recall the last time we put an acrylic face in a can, but it definitely does happen.
    If you come across acrylic though, self tappers should still work, you'd just want to avoid using the impact, or am I wrong?
  20. White Haus
    573
    160
    43
    Apr 6, 2018
    Winnipeg
    Good point Gino. I also just remembered that the big one is a flex face.
    Back to the original plan to wrap and tap.
Similar Threads - Covering (wall mounted)
  1. gabagoo
    26
    1,156
  2. KatePhillips
    12
    567
