Crease in sandblast
Xll_LUKE_llX
Hello,
I was applying a large sandblast vinyl and right in the middle I got a small crease. Is there anyway to remove it? A heat gun or something like that?
Thank you in advance.
It shouldn't matter while you're blasting. Or..... cut it out and put a patch right over the top.
Xll_LUKE_llX
Since I am applying vinyl film to a glass panel, wouldn't you be able to see a patch? From the outside. I will give it a try
Whoa cowboy....... I think we all have our terminology a little mixed up here.
Are you talking about sandblast mask for blasting a piece of glass or just plain old vinyl going onto a piece of glass permanently ??
Pat Whatley
Glass etch vinyl....hit it with the heat gun and pray. Sometimes it will settle out, usually it means recutting it.
John Butto
If it is Avery which makes the cast, it will come out sometimes, especially if it still wet, but if it calendar, nope or good luck.
Jillbeans
I also misunderstood your question.
I think you'll have to re-do.
There is no way I would use a heat gun on glass.
I try to apply etched glass vinyl dry, or sometimes I use Rapid Tac 2.
Love....Jill
