Creating color file help
Discussion in 'Flexi' started by signgirl, Jun 9, 2011.
  1. signgirl
    signgirl Member
    276
    13
    18
    Sep 13, 2005
    Illinois
    I am using flex to output to the gerber edge. I want to print one color onto white vinyl. I have given all the insides of letters a clear fill. They continue to be a solid fill same color as letter. How do I change this?
    Thank you in advance!
  2. MikePatterson
    MikePatterson Head bathroom cleaner.
    Change the color of the letters to CMYK White. The edge will not print the letters and will leave the vinyl color showing through. It will just skip over CMYK White like nothing is there.
  3. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    I think you just need to "combine" the letters, or however its labelled in flexi
  4. signgirl
    signgirl Member
    276
    13
    18
    Sep 13, 2005
    Illinois
    Thanks guys...I'll give it a try......combine sounds familiar....been a long time since I've used an edge.....truly appreciate your time in responding....hopefully I'm on my way!!!
  5. MikePatterson
    Yes you can make it a "Compound"
