Creation PCut 630 Gaps
Discussion in 'Miscellaneous Plotters' started by cowiefr, Mar 1, 2006.
  1. cowiefr
    cowiefr New Member
    17
    I haven't been in business for too long and I'm still on my first cutter, a Creation PCut 630. I realize that this cutter is not the best choice but it was a good deal for a starter. The biggest issue with this machine is that it tends to not completely trace a letter and leaves small gaps which make weeding smaller designs frustrating. I'm using WinPCSign Basic which came with the cutter. Any ideas?
    Fain
  2. South End Signs
    South End Signs Member
    61
    I'm running the same model and never have any issues like you are talking about - make sure your blade is sharp and adjusted properly and you might try increasing the downforce pressure a bit more.
    Good Luck!
  3. kevco
    kevco Guest
    adjust the blade offset. this will close the gaps up. Mine did the same thing
  4. South End Signs
    61
    Oooops, forgot to mention the offset.
    Jean-Claude
  5. cowiefr
    cowiefr New Member
    17
    You guys rock!
    Thanks alot for your replies.
    Fain
  6. xtremegraphics
    xtremegraphics Member
    277
    i also have one of those cutters ,, works great
  7. cowiefr
    cowiefr New Member
    17
    Offset?
    OK I found the offset setting. Any suggestions what I should set it to?
  8. Ogriv
    Ogriv Member
    429
    I believe the setting is .020
  9. Batch
    Batch Member
    37
    Jul 3, 2006
    What software are you guys running? And where are the offset settings?
    I have this same plotter at home and had a simular problem that seemed to be caused by the blade not being seated all the way down in the holder.
Similar Threads - Creation PCut 630
  1. XFPS
    5
    649
