crop not found roland sp 540V
Discussion in 'Roland' started by cutnedge, Aug 30, 2011.
  1. cutnedge
    cutnedge New Member
    9
    Jun 27, 2011
    texas
    Finds the first crop but cant find the second. Any suggestions?
  2. CS-SignSupply
    CS-SignSupply Very Active Member
    Is it possibly scratched? Or hazy from the laminate?
  3. The crop mark MUST be to the left of the far rightmost roller. I've had this problem before.
  4. timkaz227
    timkaz227 Member
    94
    1
    8
    Nov 29, 2010
    Charlottesville, VA
    i had this problem when i first started w/ mine.
    1. make sure you have 4-5" of material beyond your registration dots.(both ends)
    2. load the material straight using the groove on front of machine.
    3. scroll your cut head over to where the dot is. i position directly above for alignment purposes, then move it back to the right.
    4. if you still have a problem, after you center the blade over the dot in step 2, continue scroll over to the second dot to see that the material isn't skewed. Adjust straightness of material.
    If the skew is to great it won't find the second dot.
