Custom Halo Lit Sign. 3 sq.ft. with lots of WOW
visualeyez
Even under fluorescent lighting, this thing is WOW!
Welded aluminum sub-frame to attach the faces. 1/8" Aluminum faces, cut with jigsaw and painted by AutoBody shop. All holes hand drilled. Custom designed Typeface, Fabricated by Gemini. Stuffed With Aurora G2G Gen III mini modules. Removable stud mounted. All wiring hidden within, and watertight. Power supply with dimmer remotely wired inside building. Sign rides on top of Existing signage, approved for 120mph wind load and the hardest part was
attachment.php
everything!
visualeyez
Sure Do
Turned out pretty good!
attachment.php
attachment.php
visualeyez
Build Pics
I didn't take too many pictures of this. I didn't get any of the Frames or Brackets somehow. Here is a few I found.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
signmeup
Very nice! Good to see something on here that wasn't printed! What is the glowing skipping rope stuff?
Adrian
visualeyez
Haha, the Skip-Rope is Sloan FlexiBrite. The blue reatails for around $50 per linear foot. I used just under 30ft. for this sign. The Blue and Green cost 2x what the white, red and orange cost.
visualeyez
Also, at 300 lumens/ft. for the Auraura G2G modules that I overstuffed the SUSHI letters with, we had to dim down to about 20%. Those things are so effing bright, it would have caused car wrecks.
signmeup
I'm curious about the custom vacuum formed letters. You say Gemini made them? What did that service cost?
I have a Vacuum forming machine and I'd offer my services to sign shops if there was any money/demand for it.
Adrian
visualeyez
I'd have to check the Gemini catalog for that pricing. I know they charge 2x to add the leds and supply a 60 watt power supply. Custom font letters that size I think were about $90 each retail. I charged the same 2x to light them and it only cost about $100 for the modules and then $40 each for two power supplies, and $40 each for two dimmers. 5 letters SUSHI(x2) plus leds and power, I invoiced that portion at $1800.
