custom punched rolls
Discussion in 'Gerber' started by mekazilla, Sep 18, 2008.
  1. mekazilla
    mekazilla Member
    187
    Does anyone know of a company that will custom punch and or slit rolls for the edge?
    thanks
  2. Rhino
    Rhino Active Member
    535
    1
    I don't have an edge, but doesn't it take 15" rolls. And most vendors (in the States anyways,) offer punched rolls on most 15" colors.
    Sorry, I didn't answer the question at all..
  3. mekazilla
    mekazilla Member
    187
    I have a specific film material that I want to test on an edge.
  4. Robert M
    Robert M Very Active Member
    1,325
    12
    38
    Jan 23, 2007
    colorado
    custom slit
    Graphic Products may, located in So. Cal
  5. Drip Dry
    Drip Dry Very Active Member
    1,122
    1
    38
    Aug 11, 2004
    Long island NY
    Vector graphics
    Hawthorne NY
    But I'm not sure if they will do customers material anymore.
    What I've done in the past is to tape down the material you want to test onto
    a roll that is punched. It takes a little time to set it up and I know it sounds dumb but it worked for me in a pinch.
  6. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    Many suppliers can punch vinyl, if they don't in your area check with Vinyl Sign Supply in PA. Now Sign Supply USA as of last week.
  7. GARY CULY
    GARY CULY Active Member
    732
    as the other 2 men suggested you can "attach " the piece you want to test on a punched piece ..the best is to use SPRAYMOUNT [spraybomb light glue] to the backside of the test piece ,lay it on the doner piece...run er on through.used to edge on florecent orange,black on silver multi lens ..looks good
